Had my first corrupted .fit file today. I've tried some suggestions found on the web to no avail. Anyone expert in use of the tools who could help? File is here:
https://www.dropbox.com/s/gwsjuw1ccmoscuc/2021-06-08-18-03-21.fit?dl=0
Thanks!
Dave
Thanks!
Dave
This will work - 2021-06-08-18-03-21-fixed.fit
Bingo! Thank you, that's outstanding. What's the right tool to use to do this?
Fit File Repair Tool will fix most of the issues that users post here. The catch is that you would need to purchase a license and requires a Windows computer running Microsoft Access. Otherwise, sometimes files can be repaired for free using FIT File Tools. Just run the file through the section remover without any adjustments.
Thanks; I have a Win machine running MS Access, so will go pick that up.
same problem here - garmin.Kiesewetter.nl tells me unexpected end of file… i'm on a mac.2021-06-16-17-29-55.fit.zip
Repaired using Fit File Repair Tool - 2021-06-16-17-29-55-fixed.fit
