A ride has saved to my Edge 520 and is visible in the history however has not uploaded to Connect.
When I try a manual download on Garmin Connect, I get this message
Please could anyone help as I need the data.
Cheers
We don't support the file type you tried to import. |
Cheers
Please zip the fit file and attach it to this thread, as suggested in the other thread.
Thank you. Here you go.
The fix on this one was to run it through the FIT File Tools section remover without any adjustments.
Unzip the file then import into Garmin Connect using the import data page. The only oddity was the elevation spike near the beginning.
Assuming that was not correct, I fixed that with Fit File Repair Tool. -
2021-01-08-07-45-54-Alt-fixed.zip So you can take your pick which one you want to use.
Thank you so much. The second version was the more accurate. Really appreciate your help.
Thank you!
