Hi all,
My Garmin 520 plus turn by turn directions freeze after a couple minutes. For example, it freezes at "Turn left at church road" and stays like that for the entire ride. The map updates/follows the ride, so you can still follow the route by watching the purple line on the screen closely, but that means I have to watch the screen for the entire ride just to make sure I do not miss a turn. Sometimes it resolves itself somewhere down the route (last time after 80km), but often it stays like that. It has gotten worse after the latest firmware update, but also occurred before that, albeit it not that often.
Anyone else encountered this issue and if so, is there a fix? (downgrading the firmware is not really a solution as it did happen in the previous one as well..)
