For the past three long rides I've taken (30, 35 and 40 miles), I've experienced problems with the Turn by Turn navigation on my 520 Plus. It will only give me turn by turn for about the first 10 miles or so (or maybe it's limited to the first certain number of TBT) and then it has the remainder of my ride (XX number of miles ranging from 14 to 26 depending on the route) to the finish. A lot happens in that last interval... I can follow the route on the map page so the map is in the unit but the TBT is spazzing out.
I've done all sorts of trouble shooting on my own and with Garmin to the point of them sending me a replacement 520 Plus which is demonstrating the same problem. At this point I don't think it's a hardware problem.
The TBT worked previously with no issues on rides from 17 miles up to 25 miles. In looking at my sync files, the problem appears to be coincidental with updating to 4.1. No problems with TBT using 4.0 and started immediately after the 4.1 update.
I've been working with Garmin Tech support to work through this and was wondering if anyone else is experiencing the same issues?
