I had the same issue as everyone here. Mt garmin died mid ride and when i went to charge it the issue arised.
The way I got around it was ....
Plugged garmin into computer as it boots up and hangs on mass…
Plugged garmin into computer as it boots up and hangs on mass storage. Turn it off then quickly hold the lap button as it boots.
You will here a familiar sound that your garmin has been recignised by your computer and the charging icon will show on the garmin.
Now you can access your garmin from computer. I think my issue was the last file was corrupted issue known as time stamp.
Copy this file onto desktop and try and upload to strava from there. Then delete all acitivities from your device and copy all Setting, Records and Sports from garmin device onto your desktop just incase you need to reset your device.
Now unplug your Garmin and see if it boots up.... mine did without any resetting.
Hope that helps someone in the future.
