I'm not able to bring my Garmin Edge 130 (bought April 2019) to connect to a PC via USB :(
As of
I already tried 4 different Windows 10 PC,
different (otherwise working) USB cables,
tried it with or without an USB-Hub,
tried many different USB ports,
did a full factory reset of the Edge 130,
enable / disable / uninstall / update USB-drivers in the device manager,
installed latest USB-drivers from
support.garmin.com/.../
etc.
BTW, my Garmin Fenix 3HR and my Oregon 600 are working fine with all those Windows 10 PCs!
Windows always reports "Dieses Gerät wurde angehalten, weil es Fehler gemeldet hat. (Code 43) Fehler bei einer Anforderung des USB-Gerätedeskriptors" in the device manager for the Edge 130. In English this is something like "Device has stopped (Code 43). Request for the USB device descriptor failed". Checking with usbview.exe Windows does not see the Garmin USB vendor and product ID.
Interestingly, there is an older Linux PC which shows the device. (See attached text below).
But even by forcing the Edge 130 into mass storage mode, by holding the return/lap button while plugging to USB and selecting "mass storage", Linux does not recognize the 130 as a mass storage. My Oregon 600 and also the Fenix 3 are recognized as a mass storage device on that Linux PC.
I'm not 100% sure about this fact, but I think this all started after upgrading the Edge 130 to FW 3.40 using my smartphone and bluetooth. Bluetooth sync to the smartphone is still fine, but USB sync seems to be broken now.
I'm lost. Any further ideas on this issue?
Regards
Frank
Bus 003 Device 004: ID 091e:0003 Garmin International GPS (various models) Device Descriptor: bLength 18 bDescriptorType 1 bcdUSB 2.00 bDeviceClass 255 Vendor Specific Class bDeviceSubClass 255 Vendor Specific Subclass bDeviceProtocol 255 Vendor Specific Protocol bMaxPacketSize0 32 idVendor 0x091e Garmin International idProduct 0x0003 GPS (various models) bcdDevice 0.01 iManufacturer 0 iProduct 0 iSerial 0 bNumConfigurations 1 Configuration Descriptor: bLength 9 bDescriptorType 2 wTotalLength 39 bNumInterfaces 1 bConfigurationValue 1 iConfiguration 0 bmAttributes 0x80 (Bus Powered) MaxPower 500mA Interface Descriptor: bLength 9 bDescriptorType 4 bInterfaceNumber 0 bAlternateSetting 0 bNumEndpoints 3 bInterfaceClass 255 Vendor Specific Class bInterfaceSubClass 255 Vendor Specific Subclass bInterfaceProtocol 255 Vendor Specific Protocol iInterface 0 Endpoint Descriptor: bLength 7 bDescriptorType 5 bEndpointAddress 0x81 EP 1 IN bmAttributes 2 Transfer Type Bulk Synch Type None Usage Type Data wMaxPacketSize 0x0020 1x 32 bytes bInterval 0 Endpoint Descriptor: bLength 7 bDescriptorType 5 bEndpointAddress 0x82 EP 2 IN bmAttributes 3 Transfer Type Interrupt Synch Type None Usage Type Data wMaxPacketSize 0x0020 1x 32 bytes bInterval 1 Endpoint Descriptor: bLength 7 bDescriptorType 5 bEndpointAddress 0x03 EP 3 OUT bmAttributes 2 Transfer Type Bulk Synch Type None Usage Type Data wMaxPacketSize 0x0020 1x 32 bytes bInterval 0 Device Status: 0x0000 (Bus Powered)
