WIFI Connection Issues
I'm using the a new Edge 1050 with latest firmware. My husband uses the same. We both face the following issue:
  • The device connects successfully to the wifi, synchronization and updates just work fine.
  • After wakeup form standby the devices fail to connect to the wifi
    • We tested this with various wifi networks
    • The old Egde 1030+ and 1030 connected fine to the same network.
  • If the device is shut down completely and started again, it connects fine to the wifi.
So I assume there is a connection issue in the software after waking the device up from standby and I'd be glad if this could be fixed with the next firmware update.
  • This update is not available yet for my device. It might depend on the region? Garmin Express und Over the air update both say, my software is up to date.
  • Hey Ted
    Yesterday I gave it another try with the software update. Both over the air and Express updates claimed the software is up to date. But after a few connect and reconnect it finally poped up and I was able to install the upate to 31.29. And it really seems that his fixes the issue. Both devices connected and synchronized successfully after today's race. I'll do some more tests today but I think the issue is indeed fixed.
  • There are so many things that are broken with standby function. This is more intermittent than with previous versions of the software load, but even with the lasted it happened again for me again today...
  •  I'm happy to hear that you're no longer experiencing this after updating your Edge 1050 to v31.29!
     It sounds like your Edge 1050 is intermittently failing to reconnect to WiFi from standby. Are you seeing any error messages or indicators related to Wi-Fi when this occurs, by chance? Does the device reconnect after a full restart?
  • I updated my device to 31.29 and tried syncing my ride data over Wi-Fi twice. It still seems pretty glitchy. Only one of the two syncs worked, and the other one failed. I had to connect my phone via Bluetooth to get the failed one to sync. Looks like the 31.29 update didn't fully fix the Wi-Fi sync issue.
  • For about 4 weeks my 1050 doesn't connect to any network anymore. I created 2.4Ghz test networks with password 1234, no success. The old 1030 has no issues to connect to any. It happened from one day to the next. Rebooted, reset the device settings and even deleted data and reset settings didn't solve the issue. Any ideas? Version 31.29. Connection to hotspot failed as well as I thought it could be a router issue...
  • I am now on 31.31 and still experiencing Wi-Fi connection issues, currently so far that not even a reboot helps to make it work again. I changed nothing in my home network, still 2.4Ghz only with WPA2 and the most basic settings my Unifi-driven network is able to set. For the price of the 1050 this is a real shame that something like that is not working as expected...
    I have the same problem. It won't connect to the WiFi network at all. As my predecessor says... even restarting doesn't help. Please fix this problem, thank you.
  • My 1050 will only connect and sync over WiFi if I restart the device.
  • I have the same problem. I come home after a ride, and I have to manually click "Sync." It says "Connecting," and that's it. I have to restart EDGE or sync with my phone.
