WIFI Connection Issues
I'm using the a new Edge 1050 with latest firmware. My husband uses the same. We both face the following issue:
  • The device connects successfully to the wifi, synchronization and updates just work fine.
  • After wakeup form standby the devices fail to connect to the wifi
    • We tested this with various wifi networks
    • The old Egde 1030+ and 1030 connected fine to the same network.
  • If the device is shut down completely and started again, it connects fine to the wifi.
So I assume there is a connection issue in the software after waking the device up from standby and I'd be glad if this could be fixed with the next firmware update.
