Firmware version 31.29 for the Edge 1040 Series is now available. This update can be downloaded through Garmin Express or Garmin Connect Mobile when available.
Live as of 5/22/26
Change log for 31.29:
- Added Support for Bosch smart system eBikes.
- Added support for gear tracking improvements.
- Updated radar data screen to support the selected Color Mode instead of always displaying in dark mode.
- Fixed some flat roads giving credit for climbs.
- Fixed auto zoom while following a course.
- Fixed Strava widget freezing on some devices.
- Fixed ClimbPro page not showing grade/position correctly.
- Fixed time in gear for shifters not showing in ride summary.
- Fixed time in gear for Shimano eBike shifters.
- Fixed crash during course navigation.
- Fixed crash while searching for recent finds.
- Fixed translation issue causing "Day" to be added to date strings.
- Fixed elevation profile manual scale adjustments.
- Fixed dew point and UV-index in weather widget.
- Fixed crash using RTS to edit data screens.
- Fixed crash on course list.
- Fixed step goal being changed unexpectedly.
- Fixed CIQ data fields causing UI lag/freeze. CIQ data fields will now start when you enter the timer loop or when an activity is started.
- Fixed options menu while start/stop/pause overlay is present.
- Fixed Daily Suggested Workouts showing on the main menu when toggled off.
- Fixed shifter button actions for configurations with more than 4 available buttons.
- Fixed map data field locked to track up orientation.
- Fixed ClimbPro remaining climb distance on the edit page.
- Fixed speed value on speed graphical data field.
- Fixed contacts not displaying on remote widget for inReach mini 2.
- Fixed workout schedule showing only rest days after modifying target type.
- Fixed label alignment on the timer overlay.
- Fixed battery icon on the status bar page.
- Fixed slow syncing over wifi.
- Rearvue 820 Radar Display: Removed Warning Icons from orange level threats.
- General improvements to device stability and addressed various minor bugs
