Hi,
I put the new update 14.20 but didn't see how to manage Startup .txt.
How do you make it ?
Thanks
Hi,
Thanks
Hello,
I placed startup.txt in Garmin folder, it doesn't work :-(
Could you help please ?
Ivan
it should be already there
Skippy_VO2 If you have installed the 14.20 update, and restarted your device, this file should be showing up under your Garmin folder when accessed as a mass storage device. Can you confirm if you have completed that?
Here's the link from DC Rainmaker. It's for the edge 1030, but it works for the 1040
Thanks, It works fine. Empty line at the beginning of the file was the issue ;-)
