Plotted route does not display additional roads
I've had this issue for some time now, there have been various firmware updates and I have reset my 1030 but I cannot resolve this issue, which unfortunately isn't too easy to explain.
I create a route usually using rRde with GPS (ridewithgps.com) which I can import via the ride with GPS widget installed on my device without issue.
The issue is when I am riding the display will show the road/route I am cycling on but not any junctions or side roads, this causes many issues as I could be approaching a right hand turn (on the screen), but there are 2 right hand turns ahead on the road, because the display isn't showing any roads other than the plotted route sometimes I can miss the correct turn and then have to turnaround and take the next turn if that makes sense.
There must be a setting where I can actually see all roads and my plotted route so I can ensure I take the correct turn?
Any ideas?
