New 1030 upgraded from 7.5 to 9 and initially I thought I could pan through the map but (after the update?) found it was stuck where as I pan the edges do not redraw and the next time I touch the screen to pan further it recenters to the previously drawn screen and starts panning from that old spot again. Same effect as if I was never releasing my finger during each of my pan 'strokes'. Found you can use two fingers to rotate and zoom the screen while fiddling and after that is when panning started redrawing edges and not recentering on each next touch. Anyone else seen this?
