Since updating to 9.00 the screen switches to different screens while on the trainer when getting sweat on the display. Also, when charging the percentage box flashes on and off as if there is some short.
The updates tend to change the default setting. Check the screen sensitivity. It may be on high.
If adjusting the sensitivity does not fix it, you can also push the Power button during an activity and select Lock Screen.
www8.garmin.com/.../GUID-017CF5C8-FF88-494C-B2AD-64F59F51B297.html
