In the description of changes introduced in the new fw7.50, "Fixed issues with the cycling dynamics page" was written. After installing new fw in my device, dynamics page looks like in fw7.42beta.
The change went in to 7.42 beta and was released in 7.50.
The dynamics page was changed so that it would detect if the power meter you were using supports PCO. If the unit does not support then it replaces…
What you should see, assuming Assioma have released their Cycling Dynamics support is that the power phase circle diagrams at the top now work. They should show the power phase (the start and end angles…
No firmware updates published for the Assiomas for cycling dynamics yet as far as I can see, but supposed to be imminent. Interested in this as I have a set on order.
The dynamics page was changed so that it would detect if the power meter you were using supports PCO. If the unit does not support then it replaces the PCO graphic with a power graph.
This change was made for the Assioma pedals that recently added cycling dynamic support, minus PCO support.
Hello, where did you get this info from? I have Assioma Favero DUO, not sure if i'm seeing anything new in the activity page. 7.5 on 1030, obviously.
What you should see, assuming Assioma have released their Cycling Dynamics support is that the power phase circle diagrams at the top now work. They should show the power phase (the start and end angles for you producing positive power in that crank cycle). It should also show the peak power phase. The section within the power phase where 50% of the power is produced. The 50% value is the default. You can change that under the sensor details.
https://cycling.favero.com/favero-assioma-firmware-updates
Edited to add link to Assioma f/w
I know they have been talking about this update for a long time now, which is why Garmin has made these changes.
...But Assioma still did not release any update, which does not work as with Vector
Thanks for the detailed answer, we wait for Assioma now then. Wonder if it'll also show sitting/standing times.
Not sure if they are implementing that part of the spec.
