I got a new Madone this winter.
How do I add my shifting info?
I went to add sensor, selected Shifting, shifted up and down, both front and back, but it was not detected.
Thank you
Thank you
If you have an Edge Explorer then this function is not supported, if you have an Edge 1000 click this link which might help you www.sram.com/.../pairing-garmin-and-wahoo-with-gearing
Thank you, I had tried that. It never detects the sensor from SRAM. The Garmin suggests shifting the front and rear while it's searching. I did this as well as back peddling.
I have the "regular" 1000. It has the shifting sensors options.
I also tried searching all sensors, the SRAM shifting sensors just doesn't come up. I do have power from SRAM.
Maybe an excuse to get the 1030 plus?
