How do I make the G1000NXi connect to Garmin Pilot on an iPad with Wifi.
Good afternoon, my name is Andrew from Garmin Aviation Product Support! Making WiFi connections between a G1000 NXi and the Garmin Pilot App will require a Flight Stream 510 SD Card if you do not already have one.
Assuming you have a FS510 you still cannot just connect to WiFi at will. AFAIK it exists for the purpose of Database Concierge. So only when you go to update the databases will the WiFi become "active" and allow the connection.
You are correct. Once the Garmin Pilot is connected via Bluetooth and the avionics sees that there are databases available in the app to transfer the avionics will prompt a Wi-Fi connection to transfer the databases.
