Garmin marq athele update failed
Hello
it try to install update but it said update is failed then after rebooting it say updated to 0.82
/resized-image/__size/960x720/__key/communityserver-discussions-components-files/213/7115.image.jpg
  • Please help
    oxymeter dosent work
    say mismatch update software
  • Sounds like a botched beta update.  Go back to the 15.73 webpage and download the zip file again.  Unzip and then copy each file into their respective folder on the watch.  Garmin's directions below:
    www8.garmin.com/support/download_details.jsp?id=15220
    1. Download and unzip MARQ_***Beta.zip.
    2. Place the gupdate.gcd file, found in the System_v*** folder, into the \GARMIN folder of the device.
    3. If there is a Sensor Hub_v*** folder, place the gupXXXX.gcd file into the \GARMIN\REMOTESW folder of the device. Please note, not all Beta releases will include an update.
    4. If there is a GPS_v*** folder, place the gupXXXX.gcd (or 006B310700.GCD) file into the \GARMIN\REMOTESW folder of the device. Please note, not all Beta releases will include an update.
    5. If there is a ANT_BLE_BT_V*** folder, place the gupXXXX.gcd file into the \GARMIN\REMOTESW folder of the device. Please note, not all Beta releases will include an update.
    6. Disconnect from your computer and proceed through the update.
    7. If you would like to revert to the last public release software, drop the gupdate.gcd file found in the System_Backdate_v*** folder in the \GARMIN directory NOTE: If you revert to an older version of software, all of your settings will be reset to defaults.
    OR... you can try plugging your watch into a PC with a USB cable and run Garmin Express.  Hopefully this helps!
  • Thanks for reply
    but still the same problem
    i cant install neither the public 15.2 nor the beta 15.73
  • Is this an APAC device?
  • In what country did you buy it? The versions sold in Asian-Pacific countries have different software and are not compatible with the software versions listed here. If you tried to load 15.73 on an APAC device that would certainly foul it up.
  • It’s a second hand , i dont know the country of buying
    assuming it’s an apac what could i do ?
  • I opened the garmin device xml and in description it say garmin marq , no mention of apac
  • Did you try a soft (or better hard) reset?! This would be the first I would try to do ...
