MARQ Series - 14.72 Public Beta
Hello Marq customers,
The beta below is not compatible with MARQ Aviator.
Instructions for installation are available below the change log on each of the above pages.
14.72 Change Log Notes (changes since 13.10):
  • Fixed an issue where the device was not recovering as expected after being off-course during navigation.
  • Fixed an issue where the device may display a blank segment page intermittently.
  • Fixed an issue where the HRM pro update message flow was displaying the incorrect status message.
  • Fixed an issue where ‘Do Not Disturb’ prevents gesture backlight from working during the sleep window.
  • Fixed an issue where the heart rate graph may intermittently display a flat line during an activity.
  • Fixed an issue where average speed during a Surf activity may be higher than the max speed intermittently.
  • Fixed an issue with bluetooth headset connectivity during activity.
  • Fixed an issue where Garmin “Power Meter” would be incorrectly labeled.
  • Fixed an issue where sleep times may not match times reported in Garmin Connect.
  • Made improvements for post activity sensor firmware updates.
  • Made improvements for Explore navigation support.
  • Regatta timer hotkey now redirects to Sail Race activity (MARQ Captain only).
Current beta peripheral software version numbers below. New versions are indicated in red.
GPS: 4.80
Sensor Hub: 8.00
ANT/BLE/BT: 6.11
Wi-Fi: 2.60
Please note, the beta updates released on these forums are not suitable for APAC region devices.
Please send all bug reports to [email protected], and indicate which model of the MARQ Series you have in the subject line.
