MARQ Series - 13.00 Release Candidate
Hello Fenix 6 customers,
This software version is our next Public Release Candidate. This means that this software will become a public update, as long as we do not identify any critical bugs in this version. We would appreciate any feedback on v13.00. (Whether you install 13.00 now or wait for the official release in a few days, all versions of 13.00 will be identical.)
Please ensure that you are downloading the correct beta software for your specific device. The beta below is not compatible with MARQ Aviator.
MARQ: https://www8.garmin.com/support/download_details.jsp?id=15220
Instructions for installation are available below the change log on each of the above pages.
13.00 Change Log Notes (changes since 12.77):
  • Fixed an issue showing an incorrect zero value on the seven-day stress graph.
  • Fixed an issue where Daily Suggested Workouts were still present on the calendar after disabling DSW prompts.
Full Changelog, 12.20 - 13.00:
  • Added support for sport specific power zones. One can now setup their power zones for XC Ski separately from that of Cycling. (Menu > User Profile > Power Zones)
  • Added support for displaying metrics from an indoor rowing machine that supports the ANT FE-C profile (e.g. Concept 2 with the PM5 module). This includes new fields for the Indoor Rowing app: Distance, Pace, Power, and Stroke Distance.
  • Added support for an updated software update flow for ANT sensors, where the user will be prompted once they have completed the activity.
  • Added support for descriptive Varia error messages.
  • Fixed an issue with Sail Race tack assist. (MARQ Captain and Quatix 6 only.)
  • Fixed an issue where the device could crash when connected to a HRM Pro with an active Livetrack session and accessing Ski activity profiles.
  • Fixed an issue where certain CIQ elements could not be uninstalled via Express.
  • Fixed an issue where the Applied Ballistics app could not be launched through the controls menu while running another app. (tactix Delta AB only).
  • Fixed an issue where the device may fail to load a considerably long activity through the history menu.
  • Fixed an issue with setting up elevation alerts at higher elevations.
  • Fixed an issue in the paring flow where the device could return to the 'Pair with Phone?' page instead of moving forward.
  • Fixed an issue where customers with high resting heart rate would intermittently not accrue intensity minutes.
  • Fixed an issue where the device was not recording position data when racing against a downloaded course.
  • Improved the reliability of ephemeris downloads.
  • Improved the presentation of information for alarms and timers.
  • Improved the scaling of lines when zooming in/out on the map.
  • Made several code improvements for Sleep.
  • Made several code improvements for Indoor Climb.
  • Made several code improvements for daily suggested workouts.
  • Made several improvements for Livetrack.
  • Updated the Applied Ballistics bullet database to version 1215 (tactix Delta AB only).
  • Resolved an issue impacting updates to features like VO2 max and Training Status.
Current beta peripheral software version numbers below. New versions are indicated in red.
GPS: 4.80
Sensor Hub: 8.00
ANT/BLE/BT: 6.11
Wi-Fi: 2.60
Please note, the beta updates released on these forums are not suitable for APAC region devices.
Please send all bug reports to [email protected], and indicate which model of the MARQ Series you have in the subject line.
