Have to keep editing the times in the sleep activity
Could you elaborate? Which Garmin device are you using? Can you post screenshots showing the issue?
Also, did this not work for you? https://forums.garmin.com/apps-software/mobile-apps-web/f/garmin-connect-mobile-andriod/228725/sleep-pattern-times
Instinct, yer it worked but for some reason it went back to old set times
Just reset the settings again thanks
