Hi,
Using solar instinct SW 16.00
I recently used the solar intensity sensor mini widget in the round shaped location in the watch face.
I know that this mini widget takes usually 3-5seconds to update in the main solar widget, but I noticed that once used in the watch face it only refresh the solar intensity at each minute change of the clock.
While testing this and recording on video I actually also noticed that when minute changed while watch in sunlight, the intensity appeared but other display issues happened:
- Minute didn't increase it went from 29 -> 29 -> 31
- intensity level indicator were cut on the side
Is the minute refresh a bug, or is it a feature to save battery life?
See this case in picture below with 2 consecutive switches from dark->sunlight and sunlight->dark
I want to add that the mini widget refresh on minute is 100% reproducible so far , display bugs are random.
