Hi,
Due to low available space on Instinct Solar is there a possibility to Delete Course on watch but keep it on Garmin Explore Mobile?
Regards,
R.
Hi,
Regards,
R.
If you delete the course on your Instinct Solar watch and then sync again, your watch and Explore APP should match up. You can still maintain non-active course lists that you can move courses/waypoints…
Here is how I manage my Explore content on my watch (and other devices). Within Explore (I'm showing the web version below), select the tracks/courses in your Instinct Collection. Then select…
If you delete the course on your Instinct Solar watch and then sync again, your watch and Explore APP should match up. You can still maintain non-active course lists that you can move courses/waypoints back and forth from, if you use the Explore webpage. The Explore APP and Explore webpage will only sync your actively set preferred collection of courses and waypoints to your Instinct Solar.
On Web I can choose what to sync. Great! Thank you!
Here is how I manage my Explore content on my watch (and other devices). Within Explore (I'm showing the web version below), select the tracks/courses in your Instinct Collection. Then select the track you want to remove from the watch. (First Figure).
Now, select the book icon (I think it is a book) in the dialog window (second figure). Deselect your Instinct. Then click Save Collection. Your track will not be lost on Explore, but will end up in the "Unorganized" Collection. Then sync your watch with your Explore phone app. The track should then be removed from your watch, but remain in the Explore database for later use.
Thanks!
