Has anyone replaced the standard band with a QuickFit 22 band? Just curious about how people like it.
The Support page has a picture if you're wondering
atlaske-content.garmin.com/.../Instinct22_Time1541714494620.JPG
For those interested in using another band on their Instinct watch. You can release your current band using the buttons seen within the lugs extending off your watch to remove the default band. You can then attach any other Quickfit 22 sized band. The band in the picture you linked to looks nice. I have yet to personally come across an Instinct owner using a different band since the default bands match the bezel color.
Hi,
I changed mine to Quickfit 22 straight out of the box and ebay'd the original strap (I wasn't a big fan of all the holes & curved fitting and wanted a more traditional flat strap and hockey puck watch shape).
Ironically the Instinct is probably the watch that doesn't really need Quickfit. As Chris says, you can push the pins out easier than on any other watch I've owned but Quickfit is a very neat system.
The Garmin Quickfit black band matches the black tactical solar watch housing perfectly. The yellow is a really vibrant colour ..and tricky to photograph properly.
Thanks for sharing. I like the default G Shock look and I like the classic Garmin puck look too.
Is the new enduro velcro band compatible with the solar instinct?
I think that's the 26mm width and Instinct takes the 22mm size.
Garmin Quickfit22 Dark Sandstone on Instinct Solar
