When will the issue of the watch restarting during GPS activities on the Instinct 3 Solar be fixed? This has been a problem since its release, and the exact same issue is still occurring now in June 2026. Are you actually working on a fix for this?
Having read this topic made me completely forget about the solar option.
Hello. We have not been able to reproduce this concern. Since you are not able to retrieve RAM Dump, you can also save RAM region and upload the Garmin folder here: https://supportforms.garmin.com/en-US…
I recommend reporting it to Garmin through their official support website at https://support.garmin.com, sending them the crashlogs from the folder //GARMIN/Debug. Personally, I am unable to reproduce…
I recommend reporting it to Garmin through their official support website at https://support.garmin.com, sending them the crashlogs from the folder //GARMIN/Debug. Personally, I am unable to reproduce any such problem, and I guess it may be the same for them too, so they will need your cooperation, in order to track down the issue.
I use GPS, with and without navigation, daily, but did not see any crash since a long time. If you know about a way how to trigger the crash, let us know. I can try to mimmick it, and if I manage to crash the watch, I'll send a detailed report to Garmin too.
Have you tried long activities? (> 10 hours). My watch ALWAYS crashes on such activities.
I was sent instructions to enable DEBUG files. I asked for clarification on the instructions because the actions they sent me did not exactly corresponded with what the watch did when I followed them. I got no reply. That was 2 months ago. On the next long activity the watch crashed at about 9-10 hours and continued crashing repeatedly until the end of the activity after 2 hours. I sent the required files, but I noticed there was no RAM.txt file in the DEBUG folder. I asked about that, I got no reply. That was 4 weeks ago. I asked for a workaround how I could stop the reboot loop if it happens again, I got no reply.
Sorry, I rarely do so long activities
Please post the instructions, and tell us what does not correspond. Perhaps we can help. Did they send you the secure_config (or s_c) file to put into the RemoteSW folder?
With recent firmware versions, the RAM dump (Ram.bin) should be in the folder //GARMIN/DEBUG/Dump/
First of all, you can try preventing it in the following way. Before starting the activity, clean up the following folders, to make more free room on the storage:
Then, force-reboot the watch - sync, then press the Light button for some 30s till it completely shuts down (hold the button through the emergency alert, if it comes), wait little bit, and then restart. No worry, no data or settings will be lost with it.
You can also consider splitting the activity into smaller parts - either using the Multisport / Change Sport feature ("changing" always to the same activity type), or recording smaller individual activities.
If the boot loop happens again anyway, and you can't stop it, try doing the forced restart again.
I got no reply
Call them, or use the chat option.
Instructions for debug files:
When pressing Start/Stop to Save RAM Region, the About screen appeared immediately, there was no delay at all, and no RAM.txt file was created.
Before long activities, I do a cleanup: deleting all Activities, unneeded Courses (keeping only the track for the current race). I have no workouts. I think there is enough space on the watch for recording the long activity.
I think there was no Ram.bin file, I have to check the laptop where I kept a copy of what I uploaded. I got no answer when I asked if they got everything that was necessary.
About splitting: I will not have the total time then. I will not have the average pace. But I will probably stop the activity if I get multiple crashes, and start a new one. Better that losing the rest of the activity. But sometimes there is a single crash/reboot and then no other problem, and the same activity continues - with a small gap, if you notice it immediately, and a large one if you do not.
As I wrote, on I3 with a recent firmware, the RAM dump is in the folder /DEBUG/Dump/ and is called Ram.bin (or RAM.zip on AMOLED models), no more RAM.txt. And in order to generate it, your watch may need the secure_config (or s_c) file, so if the Support did not send it to you, or you did not upload it to the watch, it won't necessarily work. If they did not answer your email, call them, or use the chat.
Make sure to do the forced reboot shortly before you start the activity. It reduces the probability of a crash caused by a memory leak bug in the software. If the watch has run for hours or days before the activity, a small memory leak might have already consumed a lot of available RAM, making so the crash eminent.
If you do not manage to get it resolved, you could ask Garmin to replace the Solar model with the AMOLED version. It is built on a much more solid hardware (faster CPU, faster and orders of magnitude bigger memory), so crashes on it are much less probable, and rarely heard of. And if you avoid using the AOD mode, it has much better battery life than the Solar model anyway (better than the specs claim, in contrary of the Solar model, where the specs are overoptimistic).
If you use Multisport / Change Sport, you will have the totals and overall averages. And if really needed, you can merge the legs (or individual activities) with an external tool. I know, it is not ideal, but I mention it anyway, in the case you find no better solution.
No Dump folder under DEBUG on my watch. I was not giver any secure_config file.
I used chat and they said I should continue talking to the support person I was already talking to.
What is the firmware version?
It was 13.29 during the last crash. 14.14 now. I again did the actions for enabling debug logs after the upgrade to 14.14. Next long race is this Saturday.
About possible memory leaks: I guess it is something else, because of the multiple restarts. It would not restart continuously if the memory was cleared after the 1st crash.
Except if the leak is in the nonvolatile part of the memory, that is not cleared with a crash.
... just to explain it a little bit more: when the watch crashes for some reason, the RAM content is dumped to the nonvolatile memory (the DEBUG/Dump folder) and compressed. The compressed RAM.zip can take ~10 MB. Usually the Dump folder contains also a backup copy of the previous dump RAM_bak1.zip, perhaps even several of them. After the last crash, that I saw on my Instinct 3, the Debug folder was over 30 MB large. Now, when there is little free space on the storage, slowly being filled with a huge activity file, the watch may not be able to dump the RAM, and crashes again and again. Sure, it looks like an improperly handled exception, but unfortunately it may be the current state. I was unable to reproduce and verify the crashing loop, yet, though, so it is just a speculation.
This is also the reason, I recommended deleting the DEBUG folder (besides others) before a long activity. And, I also recommend using the "smart recording mode", instead of the mode "every second recording", disabling options like recording the HRV, temperature (they are both off, by default), and 3rd party CIQ data fields (if any used). All of that helps considerably reducing the size of the resulting activity file. Using the UltraTrac GPS mode for long outdoor activities is another possibility to consider.
