Hi,
My Fenix discharges very quickly. 20% per day without GPS workouts and without AOD. That's relatively high compared to my Epix 47mm.
Does anyone else have the same problem?
I hope that this will be fixed with the next firmware update.
Our engineers are still investigating battery drain concerns associated with the Fenix 8. They would like to point out many things that are expected to increase battery drain beyond the estimated days…
Update September 25, 2024:
Our engineers have discovered an issue that was causing incident detection to remain after, after being used in an activity. This was causing a significant increase in the battery…
Hi Laurie,
Already shared these informations with you weeks ago, enabled logging, still no reliable fix on Garmin's end. Should we trust the brand at all?
I understand the items list you have above…
Same problem here, with fenix 8 51mm amoled.
PulsOxy Setting -> manuel
AOD off
Gesture Mode on with 4Sec
No GPS activities etc.
Display Off overnight / Red Shift on Touch
Bluetooth Connection to iPhone
Issue…
Yes, the battery drains even when not wearing the watch.
Anyway, some of these tips are ridiculous:
Turn on the battery saver feature from the controls menu (Controls). I dont buy the watch to be in battery…
I was referring to:
Restart the watch
Recalibrate the battery
Factory reset (last resort but, might be necessary)
Well, It is the second F8 I have, The first one went to garmin after follow their indications and send me a new one as a replacement. Both with the same problem.
The use of external BT sensors is the source of the battery drain, as I explain in the beta forum.: https://forums.garmin.com/beta-program/fenix-8-series/fenix-8-family-enduro-3-fenix-e---public-beta-reports/i/public-beta-12-xx/battery-drain
Is it also your situation?
You have never answered my questions with regards to if you have:
Reset your watch?
Recalibrated your batter?
Did a factory reset?
That
is just one theory amongst many.
well i guest there are diferente situations,
Quite right.
There are many different theories as to what causes higher battery drain for some people but not for others. This has been the same for every single software update and likely on all watches.
It's not cut and dried. It's not a simple fix.
