Activate turn by turn audio alert.
Hello,
How to activate turn by turn audio alert on Fenix 8. I can't find where is this feature on Fenix 8. I have my headphones connected to the watch but absolutely no alert on same course as Fenix 7 (I have alert with it). Sorry for my poor English.
  • It looks like I have a similar problem on F8
    I can hear a voice, but I've lost the countdown signal in interval training. Only the vibration on the watch
  • Can anybody confirm that there are turn audio alerts with version 12.22?
    I do not find the setting to enable or disable them but also don't notice any alerts when getting closer to a turn.
    Kind anoying as I have to constanly check the watch to not accidently miss a turn.
  • When you are about to start an activity, choose Navigate>saved> pick a course
    On the next screen you should see "...More" at the bottom
    Select that,  then chose Route Settings and make sure Guidance Alert is on
    You need to do this for each type of activity, then it should be on from then on.
  • Alas, turn by turn audio alert is still very random. Twice in a row I made this one:
    - create a route in Garmin Connect Web, with navigation alerts activated
    - select a run activity on my watch and select a training (x hours at a specific pace)
    - then I also select my previously created course, "... More", I check that Guidance Alert is activated (on my headset).
    - I start my run and ...
    ... guess what? No audio turn by turn audio alert. I can see my route with the arrows on it, but neither visual indication of direction changes, nor audio alert. I still get alerts every kilometer with my pace, heartrate, etc.
    This thins is really a nightmare, I really don't know how to make it work. I think among a tens of runs, I managed to have turn by turn audio alerts work twice.
  • Did not even realized that there is a setting for turn notifications in the garmin connect course editor.
    I am going to test that.
    However I thought there would be also notifications with round trip routing, routing to a specific point or in general with all navigations on the watch.
    I am still unable to find a general setting in the menus for controlling it. (running 12.22)
  • The last time I tried it just a couple weeks ago (as just a test with a route made in connect of my normal running route) it worked pretty good.  The one thing that I did notice is that the map is for sure off / late on a few turns, and it does not call all turns turns.  My street ends with a stop sign, but is at like a little bit of an angle onto the main road (not at 90°)  and Garmin doesn't think it's a turn.
    When I was running with a running group where they provided routes (for longer runs) I would build Garmin routes by using ridewithgps and exporting those to my PC, then import into Garmin Mapsource to modify the names etc, and then again export that to a FIT file it was almost always very accurate for turns.
    I don't have mapsource on my PC anymore, but should see if I can recreate my local route with that method and see if the results are different.  Its certainly more work but once you have a workflow it was pretty simple. I did it every week and posted it to our run group to use for a while.
  • working for me after days of clicking
  • Try ringing or emailing instead of ranting on here,you might actually get somewhere.
  • if you don't want use headphones. Test with Watch audio output
    Set next:
    Watch Settings -> Focus Mode -> Activity -> Voice Alerts -> Audio Output: Watch.
    Watch Settings -> Activities -> Bike -> Bike Settings -> Audio Output: Don't change Watch
    Navigation
    "...More" - > Route Settings -> Voice Alerts -> Audio Output: Audio Output: Don't change Watch
  • NB! komoot maps without turn by turn audio
    my settings Garmin Fenix 8 43 mm:
    hold 2 left middle button and Go to:
    Watch Settings --- Focus Mode --- Activity --- Voice Alerts --- Audio Output: Connected Devices(selected by me) or Watch.
    Watch Settings --- System --- Voice --- Dialect (English US - Russian (selected))
    Watch Settings --- System --- Voice --- Male ( but i listen female only .. one time was male voice)) i think here is bug or need restart )
    Watch Settings --- System --- Voice --- Dialect Input --- English US
    Watch Settings --- Activities --- Bike --- Bike Settings --- Audio Output: Don't change (it's getting from main setting --- Watch Settings --- Focus Mode --- Activity - Voice Alerts --- Audio Output: Connected Devices)
