Sudden Battery Drain at Fenix 7 Saphire Solar
Hi everyone, hello Garmin engineers,
I’m reaching out because my Garmin Fenix 7 has had a significant battery issue from the very beginning. The battery sporadically drains completely within just a few hours, even when the watch was fully charged beforehand. This problem appeared shortly after purchase and has reoccurred several times since then.
I have already performed multiple factory resets. For a short period, the issue seemed to disappear, but it has now returned. I’m also concerned that these repeated rapid discharges may have already damaged the battery.
After reviewing the official Garmin Forums, it’s clear that this issue has been reported many times before. A search for “Fenix 7 – Battery Drain” shows 4,733 results. These posts span several years - from around the time I purchased my watch in December 2024 up to today - and the timestamps and firmware versions make the pattern easy to follow.
My question is: Is there a technical fix or a firmware update that permanently resolves this sudden battery drain issue?
Thank you in advance for any guidance or information.
LM
PS: Just to add: Currently my Garmin Fenix 7 runs firmware 25.11 - same behaviour was with previous firmware versions since Dec 2024. Would be nice to get an answer on my question above.
  • I charged it yesterday at 11:00 AM. No activities were recorded; all connections were turned off, Oxi was off, and from 11:00 PM to 7:00 AM the watch was in sleep mode. Only the heart-rate monitor was enabled. After just 20 hours, the battery level is already down to 70%.
    During the past few weeks, I have restarted the watch several times and charged it again, but the issue remained.
    Yesterday, I performed a factory reset, but the issue remained.
    I don't have any custom watch faces, widgets, or additional apps installed.
    I really hope Garmin can find a solution.
