При подключении к Гармин Экспресс обновили карты. После этого часы ушли в перезагрузку.
инструкции по сбросу не помогают.
Try this, without restoring backup
To master reset:
Hold down the Light button until it turns off
Turn on the device by holding the light button (let go as soon as it boots up)
Immediately hold Start & Lap
Once you hear the first beep, let go of start (hold down lap still)
When you hear second beep, let go of
Remove Bluetooth connection from your phone
Remove the device from Garmin connect
Follow onscreen instructions on device
the method you specified does not bring the watch out of reboot.
all the methods specified on the forum do not work. including does not work through Garmin Express. Garmin Express does not see the watch at all or sees it as an unknown device.the method you specified does not bring the watch out of reboot.
