With the last stable firmware, my LTHR is not updated when I made treshold running.
The automatic detection is enable.
Hello. I am sorry to hear you are having this issue. If you are not receiving the LTHR readings, you will first want to ensure you are meeting the requirements here: Improved Lactate Threshold Measurement…
How can we turn on again auto-detection after a manual entry?
This should be reinstated by select Menu, User Profile, Heart Rate and Power, Auto Detection, then ensure Threshold is enabled…
Still no LTHR with the last update.
Same here. Although I do a threshold run each week, my LTHR is updated only once in the last 4 months. I always run with the HRM Pro strap.
Hello. I am sorry to hear you are having this issue. If you are not receiving the LTHR readings, you will first want to ensure you are meeting the requirements here: Improved Lactate Threshold Measurement Feature
If you meet all requirements, are not receiving this, I would love to help investigate this further. Please feel free to reach out to me via Private Message.
I meet the requirements. I send you a prívate message. Thanks.
Anyone ever solve this? I can't get mine to update without the chest strap.
Check if you have automatic lactate threshold measurement enabled. A few days ago I noticed that this option was unchecked. Interestingly, I don't remember turning it off
I tried to manually lower my LTHR and then switch to automatic detection but It does not work.
Everything works fine on my fenix 7 v. 20.22. I had an lthr update after a base run today.
You are lucky.
