After the software update 15.76 my daily suggested workouts is rest day. Is a non problem for me, because rarely use that function but I noticed that,so only informing this issue
Had same issue.
After correction both days set to long run days was showed as rest days.
When I've changed long run days to other days and revert to original settings finally got some proposed activities…
Same problem here, and I always use the daily suggestions.
Same problem for me, seems to be a bug.
Unticking the long runs work for me for a while, but this has to be repeated every one or two days.
Also no long runs will be scheduled anymore
Same here with my Tactix7.
I updated yesterday from 15.74, where it worked fine.
Also my recoverytime is not calculated abd stays 0.
Same for me and settings for long run is now ticked for every day - was saturday and sunday - fenix 7x SapSol
Had same issue.
When I've changed long run days to other days and revert to original settings finally got some proposed activities for these days.
I had a (very) brief search on the internet about this, since I thought that it might be affecting other devices as well (it seems to be the case)
I found This article (don't know this outlet), where they also recommend to set the days again for long workouts (as pointed out by Adam-1972)
I can also confirm, that the settings have been changed from my previous setting, and now all are ticked as long days (as pointed out by Andreas Rosenbaum).
I now ticked all days for long off and reset my initial settings and now it seems to be fine.
I also got a blank selection list when trying to change the targettype which is now also working again.
Did someone already get an insight on if the recoverytime works again?
Just did a workout. Trainingload data is there.
Basetraining with load 100.
Recoverytime still 0
I did a Zwiftworkout, where I did not control my trainer with the watch. Just synced it afterwards. Funny thing is, that the bug came back and could be rectified by the procedure above.
Also have this problem, and had all days marked as long run days. Unclicked long run days and now have workouts for any other day except long run days, which I left for weekend.
Is anyone of you getting a recovery time calculated? Mine is 0 for the Zwift Workouts, but I got a recoverytime for ‚built-in‘/outdoor workout.
I hope Garmin will fix it soon and I also hope it is more of a backend issue rather than an on-device issue.
But on the plusside: The Bug did not come back so far, despite having done some workouts in the meantime.
I'm pretty sure I don't miss a recovery estimate on Zwift activities.
