All + Multi-band - incorrect recording
Hello,
I have just changed Garmin Venu to  Garmin Fenix 7 Solar Sapphire to have better accuracy with multiband and thats whats happaned while hiking:
I have entered the mountain shelter to have some rest and the whole blue line was drawn by garmin when i was sitting inside building (it has added around 600meters to my course).
To compare, other person had Garmin Vivomove style with GPS only from phone without any issue in that place:
I have set:
1) satellites to all + multi-band
2) fata recording "Every second",
3) CPE: current
4) Software Version 10.46
5) Activity: Hike
6) metronom: off
7) Auto Pause: off
8) ClimbPro: off
9) Auto Climb: off
10) 3D Speed: off
11) 3D distance: off
Its looks like software bug,
Top Replies
All Replies
  • Exactly that option does not exist. But I don't know at the moment if you really don't get to record the full length of the activity even during pause. After all you also have 2 datafield options for active time elapsed and overall time elapsed that keeps on counting during pause. It works for "resume later" too.
    Or you could use a 1 year old bug to stop your GPS signal.
  • Whereas one can find multiple excuses for the lack of the GPS signal, its hard to find them on the software-side. Here it looks like the position jumped to a point hundreds of meters off the last position and back near the actual position in a short time, which leads to a very high velocity. Obviously with the activity set to "Hike" this can't be true and should be processed in a smarter way than what can be seen here.
  • Here it looks like the position jumped to a point hundreds of meters off the last position and back near the actual position in a short time, which leads to a very high velocity.
    That's exactly what multipath errors can cause.
    gpsinformation.net/multipath.htm
  • Yes. And as I said in the next sentence, the software should be able to deal with it. Thats the message of my posting, and not what can cause a GPS flaw.
  • In order for the watch to do that it would have to know which GPS position fix is due to multipath and which is not.
    Suppose the situation is reversed from your scenario. You're hiking up a narrow canyon and for the last ten minutes your GPS position fix has been degraded due to multipath signals. You finally get to the top where you have an unobstructed view of the sky and the GPS constellation, eliminating the multipath errors, and allowing for an accurate position fix.
    Using your proposed design, the watch wouldn't be allowed to use the new, accurate position fix because it puts you hundreds of meters from the last fix.
  • its not that scenario, here you are going to have a lot of time between fixes.
    In my, you are in 2 different places in just a seconds which is impossible to change position that much while hiking.
    But we are all agree that possibility to pause position recording while resting should resolve problems
  • You're right. And many times I paused my hiking activity while having a stop at a hut, and then happily forgot to start it again :-) It works if you are concentrated, but not when chattering about the outstanding view or else beeing distracted. Thats just human :-)
    I'm sure in the future there will be an algorithm in the watch that does that for you. Its not that difficult but costs a certain amount of juice out of the battery.
  • its pretty simple:
    Pause recording but stll check possition. In case when gps catch that you are moving (for example 10-20meters) just notify by wibration that maybe you want to start activity again ;)
