I understand we're getting many of the features of the new Fenix 7 on the 6 retrospectively and was wondering when the Cenicross Activity profile is likely to be introduced.
Thanks!
Thanks!
I was meaning some specifics when measuring speed, etc. My maximum normal speed is 5:30min/km, but with dog this speed is 4min/km, for example. And after this run Garmin don’t known what was happened.…
No, sorry it was mistake
In that case create a blank new activity profile called "Cannicross" using the type "Other" - it will not mess up your running stats, in this way.…
If you look at DC Rainmaker's review of the F7, he talks about what features are coming to the F6.
https://www.dcrainmaker.com/2022/01/garmin-fenix7-7s-7x-in-depth-review.html
Cenicross isn't one of…
Cenicross isn't one of them (And in fact I think all features listed have been done)
I copied trailrun and renamed it to Canicross.
If you know someone with F7, copy the definition file from the folder //GARMIN/Sports to your watch. It usually works, unless the other watch uses some features not available on your model.
I was meaning some specifics when measuring speed, etc. My maximum normal speed is 5:30min/km, but with dog this speed is 4min/km, for example. And after this run Garmin don’t known what was happened. I have lot of awards, maximum values in “run”…
No, sorry it was mistake.
Is it really that easy to add an activity from different device?! Then one can manage the activity profiles list without waiting for Garmin. Sounds too good to be true though...
As I wrote - it depends. Sometimes there is no problem taking an activity definition from another model, sometimes it does not work. I tried with several of them personally, and so far it worked.
Hmm...do you know a web resource where one can find the activity profile definitions for F7?
I do not think there is any, and I do not think it would be legal. Try a friend instead.
Edit: Well, that told, if you google it up, perhaps you find something, despite it.
