Anyone got any links to long quickfit 20mm bands other than the official Garmin one?
Have bought the official strap and it is great, but I would like some other options and colours.
You'll find millions of them at www.aliexpress.com - just know that shipping from China takes longer than what most folks are used to.... Go to that site and search up '20mm replacement quick-fit straps' and then settle in for a nice long time. You can literally spend all week looking at the options.....
I can't have been looking hard enough, but I couldn't find any that had the newer quickfit style connector, was 20mm but was also longer.
Most seem to be the S5 style with the inbuilt pin. The pin on the S6 seems to be bigger.
Will try again, but do you have an example?
How come there are long/large band for 20mm and 26mm but none for 22mm? Not official at least..
But 20mm should fit 22mm? Same pin diameter?
There is a "longer" strap for the 20mm, but only because the 20mm straps are all shorter than the 22mm. Just count the number of holes in the pictures.
It appears Garmin thinks of the 6S as a "female" watch and therefore the straps are made to fit smaller wrists.
Once you buy the 6S you then have to shell out £40 for a band that fits! You don't get a longer strap in the box.
IMO the 6S is the better version, size, weight blah blah. Just shame the strap choice is so limited.
well this was the first result I saw, and there are probably 300 more than that - make sure you search AliExpress for 'Garmin 22mm replacement strap Quick Fit' - surely there will be millions of examples. Here's the first one that popped up to me:
https://www.aliexpress.com/item/4001332760647.html?spm=a2g0o.productlist.0.0.2e3e59a4XIlcJt&algo_pvid=d7e48e4b-17a4-4bad-ae9c-8798217c4898&algo_exp_id=d7e48e4b-17a4-4bad-ae9c-8798217c4898-0&pdp_ext_f=%7B%22sku_id%22%3A%2210000015731674288%22%7D
Isn't the OP asking for the 20mm band? Also, longer than what they typically call "long."
yes but if you use those basic search terms to start with, you end up getting tons more offered, some of which are the 'long' variety. And yes longer than normal.
These are my favourite, don't make your wrist sweaty or give you a rash.
