Today it’s no training status in GC again. Garmin servers all green. Anybody have same problem ?
UPDATED 10-11-2021:
A fix has just been put into place for Garmin Connect. All data is being reprocessed for you. You will see the missing days at any point now. Thanks again for all of your patience while…
I see now that yesterdays run is presented under Exercise Load but not under 7-Day Load. So something is fishy.
You can get to the TS display through the menus, but data is absent after 4th October.
Same here. No update since oct. 5th even though I was running two times after that date. Phone is on IOS 15.01. VO2Max was recorded for these runs.
My data were absent on 6 and 7 OCT, but started populating as they should from 8 OCT:
And then... today, the 9 OCT data disappeared, but 10 OCT data is present:
I think the technical term for these anomalies is, "Seriously messed up!"
Same here
Wow I thought it was just me!
Same issues here on iphone 13 ios 15.01
i am having the same issue. Do we know when this will be resolved
I am having the same issue. Yesterday with run, no VO2 max and today, no training load along with no Heat Acclimation.
All I know is that my watch have stopped recording Vo2max, the setting described here no longer exist in the watch. Last menu to turn on/off "Record VO2 Max." can not be found.
Looking at my training status and 7 day training load in the Garmin Connect, it seems that it lacks data from October 5th and onwards.
You can turn VO2 max. recording off for trail run or ultra run activities
Not there for any other activities
Hi!
I am new here but I have been following the threads for the problems concerning "No status" in Training status.
I have myself been missing status updates for the last 2 weeks, and I can't seem to uncover the cause. Following the troubleshooting guide from Garmin, I have vo2Max registering enabled for my trail runs and ordinary runs, which I have had all along. Furthermore I have had this working for several months, while making no changes to my settings that I can see. It does not matter whether I enable or disable vo2Max measuring full time either. Tried both settings for several days. No change. All of my activities are being registered with complete data as far as I can see, but the training status does not update. Like mentioned in several other posts, my performance is excellent. But my trading load is registered as with a shortage in both anaerobic and "low aerobic" load focus. My GPS is definitely on during workouts, and my heart rate is registered.
All these quotes from people here about "just train outside for 2 days" or "turn on your GPS" clearly are just Camouflaging the problem, which seems to me like either a general conflict of incompatible settings, or a bug introduced through a firmware update. A lot of people seem to be encountering this problem.
I have noticed certain other glitches recently, where for example the daily battery saver keeps turning itself off, even though there has been no training session, and I have to manually turn it back on.
But could the problems of the "No status" be caused by conflicting settings?
