(RESOLVED) - GPS Accuracy Issues Starting January 1st 2021
Fenix 6X Pro - s/w 13.10
My last 2 walking routes seem to be way off the mark when viewed on a map, whether in Garmin Connect or Strava. One had me starting 5 miles away.
Any reason for this? Is the GPS accuracy really bad? Are there any tips to improve accuracy?
Thanks for any assistance.
  • Just checked and mine's done the same.  Went outside to try the map app and after a much longer sync than usual, position was now correct
  • And just checked my wife's 6S which was showing expired - now showing current
  • FYI. In my fenix 6s, CPE shows Current tho. Today I waited for a few minutes before I started my run and I could see that the arrow on gps was slowly moving to where I were correctly.
  • If the CPE file is “current” does that mean it’s accurate, or it can still contain bad data, just that it’s the latest version of the file?
  • https://support.garmin.com/en-GB/?faq=ZCFBNlxeiM3oipPmFoYfs7
    Seems to suggest CURRENT means the dates/times stored in it of satellite positions are current. I know when I just tested the Map app after finally getting a current instead if expired it took about a minute or two to get a lock - but the position was correct whereas earlier today it was definitely off.
    It's a bit early for me to test it on an activity but I have a scheduled run for tomorrow so I can at least be aware
  • Interesting, before I wrote the post above I went outside (it’s lunch time here) had the GPS setting just set to “GPS” (no GLONASS) and opened a Walk activity and watched the map page. GPS got a green lock and the arrow slowly moved back to my home/current location. Once it was there I checked and CPE said current (then wrote the post above).
    Just went back outside and opened a walk activity again, initially the arrow showed me at my last location but as it got a green lock, the location shifted to about 100m away and just stayed there. CPE still shows as “current”.
  • I'll keep an eye out for that tomorrow. In my case the timeline was I noted the CPE was current before testing.
    Does the Map activity behave any differently?
  • Just stood in the garden with the Walk activity. Still a slow lock on but position is holding correct.
    But I'll definitely keep an eye out for this tomorrow. I'm trail running tomorrow over a path I run a lot so I can examine the final plot well.
  • This time the arrow on the map didn’t move once I got the bad position. If I turned around the map followed me but position on the map remained. CPE showed as current the whole time.
  • Odd. I'm using GPS only as well.
    One thought. Do a sync via GE or phone, and try a map lock again?
