i have it se to all day.. it is not taking pulsox readings unless I manually goto the widget and take a reading.. it was working fine before.
Just do a soft reset, by holding down the light button until the watch shut down. Obviously do a sync first.
Yep that seemed to fix it thanks
Definitely a bug. Again this morn not reading.pulsox. there seems to be a bug when the watch comes out of do not disturb mode something is not initializing correctly. I have rebooted again. Unacceptable please fix!
no such issues here. 8.1 tactix delta
Do you have Do not Disturb set to Enabled during sleep? indianajonze Do you have your Pulse Ox set to all day as well? Also, what are your Do not Disturb settings?
I opened a ticket. Do not disturb has nothing to do with that.bit is so you don't get alerts at night. Bad advice. Yes I have it set to all day
pulse ox is enabled for 24/7 tracking. do not disturb is set from 11:30pm until 9am
Do you have a battery saver mode enabled at night? Does it turn off WHR?
You mentioned your watch coming out of do not disturb causing the issue which is why I wanted to confirm the settings. You're correct, it does only affect the backlight and alerts.
If anyone else is experiencing this issue then please send me a private message or contact Product Support so you can be added to the case.
