I sure do miss the running power data field from my 5X.
Has anyone tried to copy them from another watch to the 6x? First I have to figure out the file name and that seems to be a battle of its own.
The stryd apps can be downloaded again
I saw. Makes me with I had a stryd foot pod now
Looks like Garmin has updated their running power data field for the 6X.
I'm wondering if I'm doing something wrong. I downloaded the Running Power and Combo Running Power from the ConnectIQ store and installed them on my 6X. I tried to add the running power data field onto an existing data screen. When I choose the data field, it instead shows up as a Timer on my data screen. Then I tried to add the combo running power (on a data screen of its own). It seemed to add just fine, but when I start an activity (wearing my HRM-Tri) it just displays the IQ with the exclamation mark. I'm assuming that Combo Running Power counts as one ConnectIQ data field and Running Power as the other. Those are my only two ConnectIQ fields on this activity, but actually the one seems to install as a timer instead.
I'm able to add running power to the data field but I also found that some of the data field locations will result it to crash back to Timer.
Sounds like it might be a bug. I've seen mentions of other ConnectIQ data fields having issues with certain locations like Mtthefirst said. My guess would be it has something to do with this being the first watch to support more than 4 fields on a page. Garmin may need to update it to fix the bug if that's what's causing it but in the meantime try other locations on the page to see what happens.
Same issue here ... guess we need to wait the next update on this CiQ app ... :-(
I’m having this exact same issue. Even though my first run did seem to record a chart. It didn’t give me any averages, second run tonight gave me nothing, even though the field just displays IQ with the exclamation
