Bonjour,
Sur le mode randonnée, la fonction pause automatique ne marche plus aussi bien qu'avant le problème survenu chez Garmin récemment.
Cela me fausse le kilométrage final. Y a t'il un rapport et que dois je faire?
Merci
Bonjour,
Merci
Sorry, I don't understand French. If you repeat your question in english I might be able to help.
Translation French to English:
Hello,
In Hiking mode, the automatic pause function doesn't work as well as it did before the recent problem at Garmin.
It's misleading me about the final mileage. Is there a connection and what should I do?
Thank you
In Hiking the tracking is nomally less detailed (as far as I remember it only sets a gps-beacon when you change direction. But it could also be a problem if you have enabled the 3D tracking setting in Hiking - So try do disable 3D tracking.
Besides from that yes auto-pause is also a bit slower to be activated, because if you are moving slowly - as a result to that your distance will be to long.
So it is really a matter of to long distance or the problem to pause an activity (mostly forgetting to do a pause).
