Normally, I'm using Fenix 6 pro with a Garmin heart rate monitor.
Unfortunately in my gym, the Garmin heart rate monitor is not supported.
Can a Polar H10 connect to my Fenix 6 pro and gym equipment at the same time?
(Because gym equipment reacts based on my heart rate monitor and I still would like to track the activity on my Garmin Fenix 6 pro.
Maybe check out the HRM-Dual? It's ANT and BLE.
BLE is point to point so you can only connect 1 device at a time on many BLE sensors
I have the H10 and fenix 5. There is no issues using that combination. Now for your gym equipment, the beauty of the H10 is that it has two Bluetooth transmitters and and ant+. You can connect 2 different equipment's via Bluetooth and still use something else with ant+.
You will need to download polar beat and pair with your phone to be able to enable the secondary Bluetooth transmitter and the ant+ transmitter as well. Once that is done, the H10 will be ready to be used as you intended.
I'm using now a Polar H10 in my gym to enable heart rate measurements on the gym equipment and my Fenix 6 pro at the same time - it works all fine.
