In the meantime, we have a file you can install on your watch that will fix the backlight function. I've attached the file to this post. If you'd like to install it, plug your device in to the computer. Open the "Garmin" folder, then open the "NewFiles" folder. Put the attached "backlight_mode_fix.fit" file inside the "NewFiles" folder. Now unplug your device from the computer and you should be able to reconfigure your backlight to the proper settings
Hi I have Same problem with Forerunner 735xt v9.40
any solution?? I cant see the file here.
Given the last response for this was 2 years ago and this thread is for the Fenix 5 series, I would suggest you post your issue on the appropriate sub forum https://forums.garmin.com/sports-fitness/running-multisport/f/forerunner-735xt .Pretty sure if the file for the fix was still available here it would not work on your watch anyway.
I’m facing problem with my backlight is possible share this file again please?
I’m facing problem with my backlight, i have the latest software installed. Please advise when this bug will be fixed
Hi I have the same problem on my 5S Fenix, but I can't find the file you mention to fix the problem? Thanks
Where Should I got the file? I Dont see any File in this post.
Please share the file again, I am facing the same problem.
