It's not just poles. I was showing an astonishingly low HR of 100bpm while powerhiking without poles up 2,500' of vert. This is on a Forerunner 245.
Well, I understand your point but I specifically purchased this watch because of the wrist HR monitor. It’s not simply a little inaccurate, it’s so far off an accurate reading at times to be any use at…
I had the same issue yesterday with my Forerunner 245, without using poles. The hr reading was 80-100, despite feeling I was in the 140-150 range. Our pace was very slow climbing up, but also very wet…
OHR works by detecting light changes with the surge of blood with each heartbeat. But stray light getting in under the watch can cause mismeasurement, and when this occurs in a rythmic manner, can cause the OHR to lock onto your cadence rather than your heart rate. I haven't tried OHR with my hiking poles, but I would imagine that the wrist flexing associated with poles might be the problem. AFAIK, there is no clipping algorithm based on pace. Normally cadence lock leads to over-reporting of HR while running picking up a typical cadence of around 170-180, but I imagine your cadence while hill climbing with poles is probably around 100?
The most common cause of OHR problems is poor positioning and placement. The watch band should be snug, and positioned on the fleshy part of the wrist, well away from the wrist bone. I'd recommend positioning the watch even higher on your arm to avoid interference from your poles - especially if you are using poles with a wrist stap.
If this still doesn't work, the good news is that the F5X still works with chest straps (and now works with BLE as well as ANT+). If chest straps have been working for you in the past, then you can keep using them.
I'd disagree. I have found that no matter the positioning, it does not work well on steep uphills with poles. Watch will work perfect, then hit a hill with poles and the HR goes down to 100 (despite me going harder). Then once flattens out, HR goes back to normal.
Yes, Chest strap is by far the best answer but is a work around as I'd prefer as below not to need a second piece of gear.
i also have to use the chest strap for all activities with poles. If the problem actually is the shake of the device during impact and when pulled off ground, or what i suspect: the muscles lifting the OHR-Sensor from the skin (very thin wrists, no fat).... i dont know .
for me it is a given fact that no matter how bloody tight i fix my watch or how high. with poles OHR won't work on my arm.
Relatedly, given trekking poles are part of this discussion, are your steps also undercounted when using poles? Mine are when using poles with my Fenix 5 by approximately 40 to 60 percent. I noticed this on a recent backpacking trip, where my watch registered about half the steps as my phone in my pack hipbelt pocket. Kind of a bummer from a data perspective.
yes, step counting is not working correct with poles, same for me here.
i just always use the chest strap so i got that going for me (even if this does only solve the OHR problem but not the step counting issue).
Has anybody had a solution to this? This thread is over three years old. Just curious. I have a Fenix 5s which the Wrist Heart Rate Monitor appeared to be pretty accurate for about a year or so. It suddenly began reading all over the place while running. If I switch to the chest strap then all is well again.
I will note that over the last year I have lost over 30 pounds and my body fat has dropped form 18% to 12%. Is there any link between body fat and the accuracy of the WRM readings?
It looks to me like a lot of people are having issues with the WRM on the Fenix 5s. It's very frustrating.
Thanks!
When you are serious about training w/ HR then use a chest strap.
Well, I understand your point but I specifically purchased this watch because of the wrist HR monitor. It’s not simply a little inaccurate, it’s so far off an accurate reading at times to be any use at all.
Its a feature the watch was sold with and I expect it to work.
