For those of you still experiencing incorrect distances when doing swimming activities, could you please try - 8.01 Beta Software
One of the key points of this new beta is 'Fixed an issue where the device…
I do extensive open water swimming and find that the 5X Plus generally works very acceptably. I swim in the ocean and, occasionally, after a stop I need to check that the watch has maintained the track. If it hasn't, I just hold my wrist above water for a couple of seconds and the track re-starts. For instance, I did a 7km open water swim today and lost the track only once. I am running 8.02 and GPS 2.50. Prior to 2.50, the watch was not fit for purpose but now I am more than happy with it and can concentrate on my swim rather than worry if the watch is working or not
I have a Fenix 5 saphire (with no plus). I have the watch now for 2 year and OWS still does not work. It worked until firmware version 8.0. Really good. When Galileo support has been added everything got worse. It is a problem of the GPS-Software. It is a software problem! I cannot here any longer the support bla bla. Do a hard reset. I did. All data was away. The problem remained. What is even worse than the problem is the Garmin communication policy. DC-Rainmaker wrote that there is work on an OSW patch even for the Fenix 5. Why cannot that be communicated instead of wasting my time with hard resets.
Looks like Garmin are getting closer to making the 5+ usable in the water. Had a swim this morning and got the best result I've seen since having the 5+. Last Summer's swims were virtually useless. This suggests Garmin are making real progress on what appeared to be a pretty intractable problem. Kudos for keeping it going Garmin!
This swim is along a measured buoy line with the first buoy being approximately 25m offshore and other buoys at 250m intervals to 1000m, giving a marked course of ~2000m. I have alerts set at 250m and these were going off pretty close to the buoys. The final distance is close enough to 2000m for for OWS tracking with these types of watches. The 'wandering' around of the track pretty much represents my path as I did end up well south of the 3rd buoy in the line and had to correct.
I have version 10 firmware installed but still facing inaccurate result.
Mind to share ur gps setting? Gps alone or combination with Galileo or Glonass?
What stroke are you swimming?
GPS + GLONASS
Version 10.10 and the problem keeps...:(
And haven’t you also posted that the last post about this was 5 months ago? Yet only a couple of posts earlier in this thread, granted 3 months ago but...
THis wasn’t a one-off but typical of all the subsequent swims I did with the F5+ over summer before switching over to a F6
Hi Philip, Sorry to bother you. Are you saying you got the Fenix 5 working with relatively good accuracy for OWS/ I have a Fenix 5 (not plus) and did a swim 2 days ago and accuracy was terrible. I am on Software version 19.10, GPS 2.60
5+, See picture image and post from earlier.
