Multiple Crash/Reboots during outdoor cycling activity and following a course
Hello,
I haven’t experienced this issue before, so it might be related to the latest firmware update — but I can’t say for sure, as I’ve mostly been doing indoor cycling since May. I’ve completed many indoor cycling activities on both the previous firmware and the current 27.18 firmware without any crashes.
Today I went for an outdoor ride, following a course, and my watch crashed and rebooted at least six times over a two‑hour period. From what I could tell (while biking, so not entirely certain), it seems to crash right before or right after a navigation event, such as a turn‑by‑turn prompt.
I’m currently on firmware 27.18.
Anyone else experiencing the same problem?
Are there logs on the watch that could help me diagnose the problem?
Thanks,
  • Hello  I can understand the frustration, if the watch is crashing. I would love to help investigate this further. For this, I will need some additional details. I will reach out to you via email.
  • Gents,
    I grabbed the .fit file from my ride, converted it to CSV and asked a friendly AI Assistant the following:
    "Based only on the CSV. When you see a power_up its because my Garmin watch crashed. Do you see any pattern causing the crash?"
    and it seems Human an AI agree (we might survive this after all folks!!!)
    Here is the answer I got:
    Based on the data in the event, GPS, and device logs, navigation alerts (specifically off-course warnings and route recalculations) are triggering the watch crashes.
    Key Findings & Patterns in the CSV Data
    1. Direct Correlation with Navigation (off_course)
      • There are 10 power_up events recorded across the session.
      • Every single reboot cluster coincides directly with off_course events (start / stop) or course navigation points.
      • When the watch detects you have deviated from a pre-loaded course, the background routine that triggers the off-course alert and recalculates the map/turn notifications causes a memory exception/system crash on the firmware.
    2. GPS Mode Switching During Crashes
      • In the GPS event log, immediately before and after each power_up, there are rapid sequence mode_change entries (switching between All Systems / Multi-Band Auto Select and lower power states), followed by signal_lost as the watch reboots and re-acquires lock.
    3. Device & System Context
      • Device: Garmin Epix Gen 2 Pro 51mm (Software Version 27.18)
      • Connected Sensors: Shimano Di2 electronic shifting, HRM-Pro Plus, and a Bluetooth Power Meter. (While gear changes occur frequently throughout the ride, they do not correlate to the crashes as cleanly as the navigation events).
  • Please if you have Shimano Di2 Ultegra o Durace 8100 or 9100 series, BT-DN110 battery and EMU-111 try to test changing from derailleur. For me is perfectly reproducible, same wristwatch. Reboot every single time you change it.
    I did not tested following navigation and going off course (I will try also to test it this weekend).
  • Hi, yes I do have BT-DN110, EMU-111 but I'm on 8050 series with an FD-R8050.
    I will reinstall v27.18 (I had reverted back to v26.09) and try shifting front derailleur. It should be a quick test if it reboot as often as you mention.
    I will also go for a small navigation route to try to reproduce the problem and share the data with Garmin-LF.
    Garmin is looking into it!
    --> Update. I put back v27.18, put the bike on a stand and I can consistently reproduce the problem with a caveat.
    If I simply shift the front derailleur manually using the left controls it seems to hold and haven't had a reboot.
    BUT, when I'm set in Di2 Full Synchronized Shift (S2), then as I only press the up or down shift buttons (right controls) the computer manages both derailleurs. As I shift across the cassette, and when the system automatically shifts the front chainring  and shifts the rear derailleur to keep transitions smooth then it reboots every single time.
  • I realize my test is not complete, as I haven't tried to manually shift only the rear derailleur.. It might be it causing the reboot for me. Not sure.
  • This is exactly the same error I'm having.
