- I am contacting you regarding several recurring issues with my Garmin epix Pro (Gen 2).
The most serious issue at the moment concerns sleep tracking. For some time now, my watch has regularly failed to record the first 1–2 hours of my sleep. The problem now occurs practically every night, whereas previously it happened only occasionally.
What is particularly important is that my heart rate is recorded correctly during the missing part of the sleep. HR data is available throughout this period, so this does not appear to be a problem with the sensor or heart-rate measurement. The issue seems to be that the watch simply does not recognize this period as sleep. After approximately 1–2 hours, it starts recording my sleep correctly, and the rest of the night is tracked normally.
My current software version is 27.18.
I have already tried all the available troubleshooting steps, including:
- turning the watch off and on again,
- restarting the device,
- repeatedly resetting the watch,
- checking the available sleep-related settings,
- verifying that heart-rate monitoring is working correctly.
After the first restart, the problem disappeared for exactly one night — sleep was recorded correctly that night. The following night, however, the problem returned.
Since then, I have been resetting the watch practically every day, hoping to restore normal sleep tracking, but subsequent resets do not resolve the problem. Therefore, restarting/resetting the device is clearly not a permanent solution.
I have also checked the heart-rate data and can confirm that HR is recorded normally during the period that is missing from the sleep data. The issue therefore appears to be specifically related to sleep detection and determining the correct start of sleep.
Other issues
Unfortunately, this is not the only problem I have experienced since the warranty period ended.
I have also noticed a significant reduction in battery life. The watch now lasts noticeably less time on a charge than it did previously.
There are also increasingly frequent synchronization problems with my phone. The watch often fails to synchronize with Garmin Connect, or synchronization does not complete successfully without additional attempts.
In addition, I have noticed a change in my HRV readings following software updates. My HRV is now consistently around 10–15% lower than it was previously, despite no obvious change in my routine that would explain such a persistent change. I understand that HRV naturally fluctuates and that this observation alone does not prove that the software is responsible, but the timing of the change makes me concerned that there may be a software-related issue affecting the measurements or their processing.
I have also found reports from other users of epix Gen 2 / epix Pro devices describing similar issues, particularly with sleep detection despite correctly recorded heart-rate data. I would therefore like to know whether these issues are known to Garmin and whether they could be related to the current software version 27.18.
Warranty and replacement
I have had this watch for slightly more than two years, and I have to admit that I find the situation quite disappointing.
The problems with the device started shortly after the warranty period expired — first with battery life and connectivity, and now with sleep tracking and potentially other software-related metrics.
I have generally been very happy with Garmin products and would be happy to upgrade to a newer model. However, having to spend another approximately PLN 4,000 every two years simply because a premium device starts developing multiple problems is difficult for me to accept.
I would therefore like to ask whether Garmin could offer a reasonable solution, particularly a device diagnosis, repair, or a preferential replacement/upgrade offer for a newer model.
I would also appreciate clarification on the following:
- Is the sleep-tracking issue described above a known issue with the epix Pro (Gen 2)?
- Could it be related to the current software version 27.18?
- Are there any known issues with battery life or phone synchronization on this model?
- Has Garmin received reports of changes in HRV readings following recent software updates?
- Is a software update planned to address the sleep-tracking issue?
- What solution can Garmin offer for a device that is now outside the warranty period?
If necessary, I can provide screenshots from Garmin Connect showing the missing 1–2 hours of sleep together with the corresponding heart-rate data, as well as screenshots showing the synchronization issues and any other information required to diagnose the device.
Thank you in advance for your assistance. I hope we can find a reasonable solution to this situation.
