Cycling Ability has appeared in Connect App & Web but shows No Data??
I Have plenty of data available, and it shows on my Epix in the widget, but Connect says ‘No Data Available’
Anyone got it showing in Connect??
Before you can view your cycling ability, you must have a 7-day training history, VO2 max data recorded in your user profile, and power curve data from a paired power meter. Which power meter are you using with your device? If you are seeing 'Cycling Ability' on the Epix can you please upload an image here?
Like I said, I have loads of data, a years worth, all showing in my profile, and on my epix, using Favero
Assioma PRO MX-2 Dual-Sided Power Meter Pedals.
It just doesn’t sync to Connects cycling ability page
Thank you for the additional details. Are you seeing a cycling VO2 Max in your Garmin Connect account?
Yes! I have all the data! Its always shown on my device and in Connect! But now you’ve added Cycling Ability to Connect at long last, it doesn't work!
I'm having the same issue with my Garmin Flux 2 and Forerunner 965.
Cycling VO2 Max shows and is updated after every tracked ride.
Cycling ability doesn't register in the app but shows on watch.
It’s very frustrating isn’t it? I’ve been on with Garmin support for over 3 weeks now. They don’t seem to be able to identify the problem.
We would like to look into this behavior further. I will be sending out some emails in order to collect additional information for review. **
This same issue is happening with me as well. Tons of data on my Forerunner 965 with a Cycling Ability calculated, however doesn’t show up on my Garmin Connect app.
Garmin customer support insisted I was an isolated case and the issue was with my watch. They offered a refurbished watch as a replacement on a watch that was only a year old and refused to send a new one as a replacement. In the end I sent it back to the retailer I purchased from for a refund and I cancelled my Garmin connect+ subscription as well. The customer service has been absolutely rubbish and this is the second Garmin I’ve had that has broken (my previous instinct 2 stopped charging). I’m done with Garmin. The watches break and they only ever offer a refurbished watch as a fix. The software on connect is buggy and doesn’t work correctly with numerous errors. I’ve switched to Apple Watch and I hope Garmin realise they lost a solid customer who wanted to stay.
