Constant reboots during cycling activity
After the Last update v27.18 my Epix crashed during the cycling session at least 12 times (in same session).
Just garmin heartrate band strap and stages power meter connected, no more devices. Battery at 70%.
As it is now is not usable anymore. I decided to disconnect the mobile and put the rest if the sensores as disconeccted to do not still look for them thinking this could affect. Nothing has worked. Event using during the activity the clock face (one of the activity screens with no update required just minutes and hours) still crash...
Please provide a solution. I do not get to force an update that turns the device as unusable for activity.
Regards,0000002A.TXT
Manuel
3651 (EPIX PRO - 51mm - RS9116_STAGE_DUMPS) SW ver: 2827
Build Type: RELEASE
Commit:99b899e0ff8b80275b72ab0ccddffd90a43942ed
ESN: 3453774752
09/26/26 17:48:56
STAGE dumps - BTM forced reset: OnTimerExpire 16: 0
UTC_offset: 7200
Build Type: RELEASE
ESN: 3453774752
09/26/26 17:49:16
STAGE dumps - BTM forced reset: isconnectWatchdogCallback 0: 0
UTC_offset: 7200
4314 (EPIX PRO - 51mm) SW ver: 2718
Build Type: RELEASE
ESN: 3453774752
09/26/26 18:10:27
Abnormal Powerdown
RST:0x11,PMC:0x4013
  • Same here. Exactly the same, with an ironman race in less than 3 weeks
  • Edited (updated 4/10)
    I think I have solved it for Shimano DI2 2025 for MTB But not for Shimano road BT-DN110 device (last sunday 5 hours no  reboot), but I have to test it more days. I followed this steps I found here in the formun for similar issues, it's in spanish, but it is going to those folders and delete all the files you will found there.
    Go into the Garmin folder and delete the content of all of this folders (not the folder itself please!). Plesae note that deleting all the activities you will loose all the stored activities.
       - Garmin/RemoteSW: Bórrala por completo. Esta carpeta almacena las actualizaciones de software de componentes (como el Bluetooth o el GPS) antes de instalarse. Si un archivo se descarga mal, genera un bucle constante de reinicios. El reloj la volverá a crear limpia automáticamente.
       - Garmin/NewFiles: Borra todo lo que haya dentro. Aquí es donde se reciben los trayectos (.GPX/.FIT), entrenamientos o pantallas descargadas. Si un trayecto está corrupto, el reloj se reiniciará cada vez que intente procesarlo.
       - Garmin/Activities: Elimina los archivos antiguos. Si el reloj está muy lleno o hay un archivo de actividad dañado que no se sincronizó bien, la memoria colapsa. Nota: Asegúrate de tener todo sincronizado previamente con la app Garmin Connect.
       - Garmin/REMOTELOGS and Garmin/EVNTLOGS: Puedes borrar los archivos de texto o registros de errores que haya dentro. No afectan en nada al sistema y liberan caché.
    After that: -> install the last version of Software already installed in the watch:
       Powercycle the watch.
       Reinstall the software version with these steps:
          Hold the menu button.
          Select System.
          Select About.
          Press the Light button roughly 8 times.
          Select Reinstall software.
    Plesae tell me if those solve the problem also for you.
  • Thank you. You did that on garmin express, right?
  • You do not need It.
    Just connect to a Windows 11 pc to deleite files, and the second step, to reinstall from the watch itself.
  • Hi,
    Still no issues after applying the above fix?
    Do you have a Di2 sensor connected to you watch?
    Thank you.
  • I'm not the user who posted this, but I've disconnected the di2 from the watch, went for a 3 hour bike ride, plus a brick run afterwards and the watch hold up, it didn't reboot this time. Don't know if it was luck, but it didn't happen.
  • OK, providing more information:
    The solution I provided above works with Shimano DI2 XTR for the new 2025 version (edited above) but not for Shimano older BT-DN110 combined with Ultegra 8100 gear.
    As Jb and 9948851 says, they are completely right. Does not work with road Shimano Ultegra 8100 for example. I confirmed this, as they say if you disconnect di2 on sensors, the watch simply does not reboot. As easy as that.
    Constant reboots with shimano DI2 CONNECTED. I changed to do more test Shimano Etube app  from ANT to ANT /Bluetooth but same result. I also deleted the sensor and repair again after the change with the same result.
    All components are updated to the latest version as you can see in the picture (E-Tube application).
    In hope to Garming doing further investigation, I have connected three sensors. DualBand Garmin Band, Stages Power Meter (last weekend assionma mx2 with same results of rebooting), and Shimano Di2 BT-DN110 with EW-WU111 with lastest firmware on both See image)
    Please Garmin help us on this. This error is completely reproducible. Give us a solution.
    Constant reboots  make the device useless
  • Your diagnostic seems right. I also have BT-DN110 and FD-R8050 (and RD-6870-GS in the back).
      : Please share this feedback with your engineering team. Thank you.
