Virtual run stuck on waiting to pair
My virtual run app has worked great for as long as I remember, but now in zwift it is stuck on the ‘ready to pair’ screen. Any suggestions? I’ll see HR coming through, zwift reports itself as connected, but the app is just sitting there. I’ve tried zwift on both iPhone and iPad, I’ve tried restarting, re-pairing.
  • If you are still experiencing this, please try updating the Epix gen 2 through Garmin Express and then try turning the watch off and back on. Then try re-pairing.
  • Thank you! I appreciate it, but unfortunately did not work. The watch is in the beta program and there was an update, and I deleted/re-paired and rebooted everything. Same result.
  • Hello  If you have not already, we would recommend installing the latest Live software version 27.18 using Garmin Express, or Check For Updates in the watch menu.
    If this is still occurring, I would love to see a video showing what you are seeing so we can see the steps you are taking, and what you are seeing on the watch. You can upload this here: https://supportforms.garmin.com/en-US/form/file-uploader/
  • Thanks! I submitted a video showing the epix waiting on the ‘ready to pair’ screen while zwift starts, but also showed my Fenix 6 that works fine. Sorry for quality, tough to navigate several devices and hold a camera. (I have used the epix for virtual runs for quite some time without issue, this problem is new.)
  • i have started to face the same issue today.... and i have all of the devices up to date.... and using mac, windows.. iPad. iPhone etc....  i have also submitted a video and the garmin express report file requested...let's see what we get for options...or fixes
  • I have a Technogym MyRun treadmill paired to my Fenix 7 under Sensors & Accessories, correctly recognized as FP – MyRun (Foot Pod category, running shoe icon), status: Connected.
    Context on Virtual Run: I was previously using Virtual Run to relay MyRun data to Zwift, and distance was very accurate and consistent — typically within about 10m of the treadmill's own displayed distance, run after run. After updating to 27.18, Virtual Run broke (matches the RSC 0x1814 "advertised but unavailable after connection" issue already reported elsewhere in this thread), so I switched to using the plain Treadmill activity profile instead, pairing the Foot Pod directly to Zwift and running the Treadmill activity on the watch in parallel.
    Important caveat: I had not previously used the Treadmill activity profile before switching to it post-27.18, so I cannot confirm whether the issue below is a new regression introduced by 27.18, or a pre-existing bug in the Treadmill profile that I simply hadn't encountered before. I'm reporting it in case it's useful, but I want to be upfront that I can't establish a "before/after" comparison for this specific activity type the way I can for Virtual Run.
    The issue itself: distance and pace in the Treadmill activity have been wildly inconsistent, despite the Foot Pod showing as "Connected" throughout:
    • One Treadmill session: watch showed 6.12 km vs. 4.15 km actual (treadmill console) — ~47% overestimate
    • Another Treadmill session: watch showed 3.6 km vs. 3.79 km actual — underestimate
    • A third Treadmill session (data below): Calibrate & Save corrected the total distance to 4.15 km (matching the treadmill), but the underlying per-second data shows a clear internal inconsistency:
      • Avg Run Cadence: 126 spm
      • Avg Stride Length: 1.16 m
      • Cadence × Stride Length ≈ 146 m/min ≈ 8.8 km/h
      • But Avg Pace reported for the same session: 10:06/km ≈ 5.94 km/h
    That's roughly a 48% mismatch between what the cadence/stride-length numbers imply and what the watch's own pace figure shows for the same session — evidence that the underlying speed/distance calculation isn't being driven consistently by one real data source, even though the Foot Pod connection itself is active.
    For comparison, a session run under the plain Run activity profile (same treadmill, same Foot Pod paired) showed a smooth, consistent pace with no equivalent inconsistency — so whatever's happening currently appears specific to the Treadmill activity profile.
  • My Fénix 7 pro has developed this same problem today and was working fine on 2nd September and there have been no updates since then
  • I also have the same issue, which started a few days ago. Software version 27.18 Fenix 7. tried connecting to Zwift on phone and iPad; both the same. updated all, turned all on and off, repaired etc to no avail
  • GC has been updated maybe the older version had bugs that disrupted connections.
  • My Epix Pro 2 has also developed this problem. I have tried all the suggestions but does not work. Please help as it’s very frustrating!
    Linda
