Have anyone beeen able to connect with latest bosch software, their Epix 2 (non pro) to bosch ebike?
or does the epix2 software is to old to work?
I know there have been some changes and definitelly edge 540, etc can be now connected with bosch
Only navigation units received the SW to connect to the Bosch Smart system.
This is done through their Bosch flow app.
No Garmin watch, not even my Fenix 8 with Beta enabled have this SW available still…
I hope this will come for the watches soon, too.
ahh, i see i thought there was option to for watch too :(
No Garmin watch, not even my Fenix 8 with Beta enabled have this SW available still.
Not sure what the Garmin is waiting for as this is bottlenech on Garmin side only (i contacted Bosch to confirm that)
Hi! I’m developing an alternative called eBikeDataLink that uses an iPhone as a bridge between a Bosch Smart System bike and a Garmin Connect IQ data field. It shows battery, remaining range, rider power and cadence. I’ve tested it on a Fēnix 7X and an Edge 530, including with the iPhone locked.
I haven’t tested the Epix 2 myself, so I can’t confirm whether the latest software supports a direct connection.
If you’d like to try it on your Epix 2, the beta is free:
https://testflight.apple.com/join/XvHdpbc3
You’ll also need the Garmin data field:
https://apps.garmin.com/apps/188b0529-0b7f-44bd-a8b6-481b78a92c13
You do need to carry your iPhone during the ride. I’d appreciate hearing whether it works with your Epix 2!
Hey,
thanks a lot.
do you think it might work as well on Fenix 8?
Yes, it should work on the Fēnix 8 as well. If you’d like to test it, send me an email at [email protected] and I’ll add you to the beta.
Once you’ve tried it, I’d really appreciate it if you could send me your feedback by email too.
Tested it. I was able to run the "EbikeDataLink Power" which gave me: Riders Power, Cadence and Estimated range.
So, at least something for sure and it was stable as well.
But we need to have it saved in the Garmin activity to be able to use those data for example to update my VO Max which is not the case as of now.
Looks nice!
Do you plan to do that to android phone?
Hi,
Thanks for testing! We’ve already added a Power Meter mode that sends power and cadence to Garmin as native Bluetooth sensor data. I’ve also personally confirmed that VO₂ max updates work with this mode on my Fēnix.
To set it up:
Use Garmin’s standard Power and Cadence fields during your ride. VO₂ max updates still depend on your device and Garmin’s usual activity requirements.
If you don’t see the mode selector, let me know which app version you’re using.
Thanks again for testing!
