Caller ID not showing after latest update to 9.36, nor the number or the name, after ringing name shows on missed calls, what could be the problem?
IPhone or android?
Not seen an issue on mine with Android. Only time I can occasionally see this if not in my contacts, but usually still get the number calling unless that has been blocked.
Latest android, Samsung device. All notifications work properly, just problem with showing name or number.
Android phone with Verizon - My voter ID isn't showing either. Only the phone number is shown.
This usually happens when you use a 3rd party app, like for example the TrueCaller, to handle the calls. For some reason TrueCaller does not pass the caller's name to the system notification.
... another possibility is the missing permission of the GCM app to the address book. Verify whether all permissions are granted to the GCM app.
I doubt the firmware has anything to do with that - the watch simply displays notifications as they are sent to it by the phone through the GCM app.
That worked. Thanks!
Not in my case
Not in my case
Just to be clear, you granted permission for Connect (GCM) on your Android phone to have access to your Contacts and you are still not getting caller ID?
