System Software 23.00
Hello Enduro users,
Today we started the rollout of software version 23.00 this update also includes a GPS and Senor hub and language file updates, currently we are at 90% with this update and we will increase the % as time goes by.
Change Log
Added major update to Training Status widget. The main widget now displays Training Status, HRV, and Acute Load data. The widget also contains its own glance view containing Acute Load, Load Focus, VO2 Max, Recovery, Heat Acclimation, and Altitude Acclimation data.
Added a new Acute Load graph and Heat Acclimation graph, which can be accessed via the updated Training Status widget.
Improved race time predictions.
Fixed a potential issue where random text would be displayed on InReach messaging.
Fixed a potential issue where the Daily Floors Climbed Goal alert would not alert.
Fixed a potential issue where Battery Saver mode would randomly turn on after an activity or accessing a menu.
Fixed a potential UI issue where the watch face would only partially update.
Fixed a potential issue where the Virtual Parter Time Ahead/Time behind would not update.
Fixed a potential issue where the device would prompt to update software even when system software is up to date.
Fixed a potential issue where swim workouts would loop back to previous sets.
Fixed an issue in the Strength activity that would display an invalid value when the set timer goes over one hour.
Fixed an issue when calibrating altitude via the DEM option where the prompt to enter sea level pressure was skipped.
Fixed an issue where RCT could disconnect while on the widget glance.
Fixed an issue where the device was not detecting floors climbed when in a Floor Climb activity as a part of a multisport.
Fixed an issue on the Xero widget would be unable to acquire GPS.
Fixed an intermittent issue where using a hot key to open a timer from the Spotify app will return the user to an empty screen.
Fixed an intermittent issue where the device would not properly sync privacy settings with Garmin Connect Mobile.
